Aller au contenu principal
Anglais
Français
Traduction de l’étape 39
Étape 39
Install three AA batteries in the battery compartment. Upon inserting the final battery, the four LEDs should start flashing in a clockwise pattern. Congratulations, you did it!
  • Install three AA batteries in the battery compartment.
  • Upon inserting the final battery, the four LEDs should start flashing in a clockwise pattern. Congratulations, you did it!
  • To play the game, follow these instructions:
  • Remove one of the batteries. Then, reinsert the battery while holding the Level 2 button for no sound or the Level 1 button for sound. Release the button a couple seconds after the battery is inserted. The game will eventually power off on its own. To wake it up to play, press either the Level 1 button to play with sound, or the Level 2 button to play without sound.
  • As the LEDs blink in a clockwise rotation, press one of the four buttons to select the level of difficulty (printed above or below the buttons).
  • After selecting your level, the game begins. It is a typical Simon Says-like memory game. The LEDs will flash one light, then you have to click that button. Then it will flash two lights and you have to click those two buttons in order.
  • The game progresses until you mess up the pattern or take too long to respond.
  • Have fun! And be sure to tell us all about your high scores in our Story section.
Installez les trois piles AA dans le compartiment à piles.
Lorsque vous placez la dernière pile, les quatre LEDs devraient s'allumer successivement dans le sens des aiguilles d'une montre. Félicitations, vous avez réussi ! Pour jouer au jeu, suivez les instructions suivantes :
Retirez l'une des piles. Ensuite, remettez-la en place tandis que vous appuyez sur le bouton "Level 2" (niveau 2) pour jouer sans son, ou sur "Level 1" (niveau 1) pour jouer avec du son. Relâchez le bouton choisi après avoir inséré la pile. Le jeu s'éteindra de lui-même après un certain temps.
Pour le réveiller pour jouer, appuyez soit "Level 1" pour jouer avec du son, soit sur "Level 2" pour jouer sans son.
Lorsque les LEDs clignotent dans le sens des aiguilles d'une montre, appuyez sur l'un des quatre boutons pour sélectionner le niveau de difficulté (imprimé au-dessus ou en-dessous des boutons).
Une fois le niveau sélectionné, le jeu commence. C'est un jeu de mémoire : l'une des LEDs va s'allumer, puis il faudra appuyer sur le bouton correspondant. Ensuite, deux LEDs vont s'allumer, et il faudra appuyer sur ces deux boutons dans l'ordre.
Le jeu progresse jusqu'à ce que vous fassiez une erreur dans le schéma, ou que vous mettiez trop longtemps à répondre.
Amusez-vous bien ! Et partagez vos scores dans notre section "Histoire".
