Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 3
Étape 3
A top metal plate, power cable, and three delicate looking cables guard the entrance to the cave hard drive bay. The power cable with socket attached lifts away easily. Removing four T8 Torx screws releases the plate. Use a T8 screwdriver, as it is difficult to gain purchase on the screws with an L-key and risks rounding them.
Release Metal Plate
  • A top metal plate, power cable, and three delicate looking cables guard the entrance to the cave hard drive bay.
  • The power cable with socket attached lifts away easily.
  • Removing four T8 Torx screws releases the plate. Use a T8 screwdriver, as it is difficult to gain purchase on the screws with an L-key and risks rounding them.
  • Once the four screws are removed, the metal plate simply lifts away.
Une plaque métallique supérieure, un câble d'alimentation et trois câbles délicats gardent l'entrée de la baie de disque dur de l'entrée.
Le câble d'alimentation avec prise montée se retire facilement.
Le retrait de quatre vis Torx T8 libère la plaque. Utilisez un tournevis T8, car il est imprudent d'économiser sur ce tournevis, car un autre outils risque de les arrondir.
Une fois que les quatre vis sont enlevées, la plaque métallique se soulève simplement.
