Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 4
Étape 4
Always inspect your new spark plugs before installing. Check the gap on your replacement spark plugs with a feeler gauge. It should be set to .040 inches (1.016mm). If they are not pre-installed, make sure that the crush washer and terminal nut are installed. If they are not pre-installed, make sure that the crush washer and terminal nut are installed.
Checking the new spark plug
  • Always inspect your new spark plugs before installing. Check the gap on your replacement spark plugs with a feeler gauge. It should be set to .040 inches (1.016mm).
  • If they are not pre-installed, make sure that the crush washer and terminal nut are installed.
Inspectez toujours vos nouvelles bougies avant d'installer. Vérifiez l'écart sur vos bougies d'allumage de remplacement avec une jauge d'épaisseur. Il devrait être réglé sur 0.040 pouces (1mm).
Si elles ne sont pas pré-installés, assurez-vous que la rondelle compression et l'écrou terminal sont installés.
[title] Checking the new spark plug
[* black] Always inspect your new spark plugs before installing. Check the gap on your replacement spark plugs with a feeler gauge. It should be set to .040 inchesinches (1.016mm).
[* icon_note] If they are not pre-installed, make sure that the crush washer and terminal nut are installed.
