Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 1
Étape 1
Begin jacking up the front driver's side corner of the car by placing a jack about 5" back from the front wheel cutout on the long vertical part of the frame. This is the jacking location as stated in the owner's manual. It is helpful, but not necessary, to jack both sides of the car. Since the oil drain plug is located to the passenger side of the vehicle centerline, jacking up just the driver side is sufficient to drain the oil.
  • Begin jacking up the front driver's side corner of the car by placing a jack about 5" back from the front wheel cutout on the long vertical part of the frame. This is the jacking location as stated in the owner's manual.
  • It is helpful, but not necessary, to jack both sides of the car. Since the oil drain plug is located to the passenger side of the vehicle centerline, jacking up just the driver side is sufficient to drain the oil.
Commencez par placer le cric à environ 12 cm du début du bas de caisse côté conducteur, sous la longue partie métallique verticale. Il s'agit du point de levage qui est indiqué dans le manuel du véhicule.
Il est peut être plus simple de lever les deux côtés de la voiture, mais ce n'est pas obligatoire. Comme le bouchon de vidange est situé du côté passager, lever seulement le côté conducteur suffit pour que l'huile s'écoule.
