Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 6
Étape 6
Be careful when flipping up the logic board. The headphone jack and docking port are attached to the board. Gently lift the logic board (and attached components) upward. The smaller portion of the logic board that resides underneath is very bendable and frail. Make sure not to pull the spudger upward when using it to detach the small board. Use only side-to-side movement.
  • Be careful when flipping up the logic board. The headphone jack and docking port are attached to the board.
  • Gently lift the logic board (and attached components) upward.
  • The smaller portion of the logic board that resides underneath is very bendable and frail. Make sure not to pull the spudger upward when using it to detach the small board. Use only side-to-side movement.
  • Slide the spudger under the small portion of the logic board. The board should come loose once the spudger has slid almost all the way to the other side.
Insérez ici votre traduction
