Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 8
Étape 8
Once the draining oil has slowed to a drip, wipe the area around the drain plug with a clean rag or towel. Replace the drain plug and tighten it with a 14 mm socket or box end wrench. Ensure that the drain plug is tight, but do not over-tighten it. You may risk stripping the threads or cracking the oil pan—a costly error.
  • Once the draining oil has slowed to a drip, wipe the area around the drain plug with a clean rag or towel.
  • Replace the drain plug and tighten it with a 14 mm socket or box end wrench.
  • Ensure that the drain plug is tight, but do not over-tighten it. You may risk stripping the threads or cracking the oil pan—a costly error.
Insérez ici votre traduction
