Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 14
Étape 14
Grab the yellow handle of the engine oil dipstick at the front of the engine and pull the dipstick out. Wipe down the dipstick with a rag or towel, reinsert it, then pull it out again to get a an oil level reading. The oil level should be somewhere between the two holes, which denote the minimum and maximum levels. Add or drain oil as necessary until you have an appropriate level.
  • Grab the yellow handle of the engine oil dipstick at the front of the engine and pull the dipstick out.
  • Wipe down the dipstick with a rag or towel, reinsert it, then pull it out again to get a an oil level reading.
  • The oil level should be somewhere between the two holes, which denote the minimum and maximum levels. Add or drain oil as necessary until you have an appropriate level.
  • It takes one quart of oil to change the level from minimum to maximum.
  • Reinstall the dipstick and oil filler cap. Twist the cap clockwise until it is snug.
Insérez ici votre traduction
