Aller au contenu principal
Anglais
Français
Traduction de l’étape 4
Étape 4
Here you will need your 7/16 socket and your slip joint pliers. First you will need fit your 7/16 socket on the hex nut on the bottom of the machine and your slip joint pliers on the rod sticking through the top of the machine. You will then loosen the nut with your socket while holding the top with your slip joint pliers. By doing this you will be removing the flywheel thus giving you more room to remove the electrical connections.
  • Here you will need your 7/16 socket and your slip joint pliers. First you will need fit your 7/16 socket on the hex nut on the bottom of the machine and your slip joint pliers on the rod sticking through the top of the machine. You will then loosen the nut with your socket while holding the top with your slip joint pliers.
  • By doing this you will be removing the flywheel thus giving you more room to remove the electrical connections.
Insérez ici votre traduction
