Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
Lift the car high enough so that you can place a jack stand beside the jack. Slide the stand under the car, making sure that the top of the stand will connect to a solid portion of the car's frame when the car is lowered. Slowly lower the jack so that the car is resting on the jack stand. Remove the jack.
  • Lift the car high enough so that you can place a jack stand beside the jack. Slide the stand under the car, making sure that the top of the stand will connect to a solid portion of the car's frame when the car is lowered.
  • Slowly lower the jack so that the car is resting on the jack stand. Remove the jack.
  • Many hydraulic jacks are lowered by placing the open end of the handle over a knob and turning it counter-clockwise. Consult your owners manual for your jack if you don't know how to lower it.
  • Never work underneath a car that is only supported by a jack. The jack may slip or fail, resulting in serious injury or death.
Insérez ici votre traduction
