Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 4
Étape 4
Using your screwdriver, or anything slim enough to fit, gently push the white lever back. Put your object on the right hand side of the lever, slightly pushing right as you push back. The lens will drop down and your drive door will open about a quarter inch. Gently pull the tray to its open position. If you have a game stuck in your drive, this would be the ideal time to remove it.
Manually Ejecting the Drive
  • Using your screwdriver, or anything slim enough to fit, gently push the white lever back. Put your object on the right hand side of the lever, slightly pushing right as you push back.
  • The lens will drop down and your drive door will open about a quarter inch.
  • Gently pull the tray to its open position. If you have a game stuck in your drive, this would be the ideal time to remove it.
  • If your drive door sticks when pressing the eject button now is the ideal time to replace the drive belt.
  • Remove the drive belt and replace it with a new one. Belts approximate location highlighted.
  • Don't forget to reset the white lever during reassembly.
Insérez ici votre traduction
