Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 3
Étape 3
Press outwards on the 2 plastic retaining tabs Gently lift PCB over tabs
Drive PCB Continued
  • Press outwards on the 2 plastic retaining tabs
  • Gently lift PCB over tabs
  • Only remove these ribbon cables if you need to remove the entire PCB. These are friction fit ribbon cables. In my case, they have a piece of tape holding the ribbon to the connector
  • If your drive is "dead" this is where I would suggest replacing the electrolytic capacitors on the board. The Samsung [Ver. B] has 13 (9 Radial/4 SMD)
Insérez ici votre traduction
