Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 5
Étape 5
Do not push the AirPort/Bluetooth card away from the logic board more than 1-2 mm. Doing so may cause severe damage. With a firm grip on the edges of the AirPort/Bluetooth card, pull it straight out of its socket on the underside of the logic board. Try not to touch the antenna connector sockets with your fingers, as the oils can corrode the metal and prevent good contact.
  • Do not push the AirPort/Bluetooth card away from the logic board more than 1-2 mm. Doing so may cause severe damage.
  • With a firm grip on the edges of the AirPort/Bluetooth card, pull it straight out of its socket on the underside of the logic board.
  • Try not to touch the antenna connector sockets with your fingers, as the oils can corrode the metal and prevent good contact.
Insérez ici votre traduction
