Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 27 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red). Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it. Repeat this step with the other adhesive strip and remove it.
  • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
  • Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
  • Repeat this step with the other adhesive strip and remove it.
  • If either adhesive strip breaks before it's removed, use a plastic card to slice through the remaining adhesive.
Si nécessaire, une carte en plastique peut servir à faire céder la bande adhésive inférieure restante.
-[* icon_note] If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
+[* icon_caution] Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
+[* black] Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
+[* black] Repeat this step with the other adhesive strip and remove it.
+[* icon_note] If either adhesive strip breaks before it's removed, use a plastic card to slice through the remaining adhesive.
