Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 20 tutoriels qui comprennent cette étape.
Traduction de l’étape 4
Étape 4
Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the top side of outer case below the logic board before proceeding.
Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
Remove the Mac mini Logic Board Removal tool.
[* icon_caution] To remove the logic board, the two cylindrical rods of the Mac [* red] Insert the [product|IF145-159|Mac |
[* black] Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case. |
[* icon_note] Cease prying when the I/O board is visibly separated from the outer case. |
[* black] Remove the Mac |
