Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 25 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Apply a suction cup halfway up the heated side. Be sure the cup is completely flat on the screen to get a tight seal. While holding the iPad down with one hand, pull up on the suction cup with strong, steady force to create a gap.
  • Apply a suction cup halfway up the heated side.
  • Be sure the cup is completely flat on the screen to get a tight seal.
  • While holding the iPad down with one hand, pull up on the suction cup with strong, steady force to create a gap.
  • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
  • Be careful to only lift the glass enough to insert an opening pick—any more and you risk cracking the glass.
Placez soigneusement une ventouse à mi-hauteur du côté chauffé.
Assurez-vous que la ventouse est complètement plate sur l'écran pour obtenir une bonne adhérence.
Tout en maintenant l'iPad enfoncé d'une main, tirez sur la ventouse pour séparer légèrement l'ensemble panneau frontal et la coque arrière.
Faites attention à soulever la vitre juste assez pour insérer un médiator – un peu plus et vous risquez de fissurer le verre.
-[* black] Carefully place a suction cup halfway up the heated side.
+[* black] Apply a suction cup halfway up the heated side.
[* black] Be sure the cup is completely flat on the screen to get a tight seal.
-[* black] While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel assembly from from the rear case.
-[* icon_caution] Be careful to only lift the glass enough to insert an opening pick—any more and you risk cracking the glass.
+[* black] While holding the iPad down with one hand, pull up on the suction cup with strong, steady force to create a gap.
+ [* icon_note] Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
+ [* icon_caution] Be careful to only lift the glass enough to insert an opening pick—any more and you risk cracking the glass.
