Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 21 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
While holding the glass up with the suction cup, slide the point of an opening pick into the gap between the glass and body of the iPad. Don't insert the opening pick any deeper than 2 mm into the side of the display. Inserting the pick deeper than 2 mm could damage the backlight assembly, LCD display, or touchscreen.
  • While holding the glass up with the suction cup, slide the point of an opening pick into the gap between the glass and body of the iPad.
  • Don't insert the opening pick any deeper than 2 mm into the side of the display. Inserting the pick deeper than 2 mm could damage the backlight assembly, LCD display, or touchscreen.
Tout en tenant le verre avec la ventouse, faites glisser la pointe d'un médiator dans l'espace entre la vitre et le reste de l'iPad.
N'enfoncez pas le médiator plus profondément que le joint noir sur le côté de l'écran. Insérer le médiator trop loin risque d'endommager l'écran LCD.
[* black] While holding the glass up with the suction cup, slide the point of an opening pick into the gap between the glass and body of the iPad.
[* icon_caution] Don't insert the opening pick any deeper than the black bezel on2 mm into the side of the display. Inserting the pick too far maydeeper than 2 mm could damage the LCDbacklight assembly, LCD display, or touchscreen.
