Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 16
Étape 16
Remove six screw covers (if present) from the screen bezel, and remove the 6 screws. Use a spudger to release the retaining clips around the edges of the bezel and the bottom of the hinge cover, and lift off the bezel. You now have access to the LCD, the inverter at the bottom of the screen (this powers the backlight) and the WiFi antennae along tne top.
Screen disassembly
  • Remove six screw covers (if present) from the screen bezel, and remove the 6 screws.
  • Use a spudger to release the retaining clips around the edges of the bezel and the bottom of the hinge cover, and lift off the bezel.
  • You now have access to the LCD, the inverter at the bottom of the screen (this powers the backlight) and the WiFi antennae along tne top.
  • A few more screws allow you to remove the LCD panel from the screen shell, which you will need to do if you have a bare replacement LCD. Without the protection of the screen shell the LCD panel is delicate and should be handled with care.
Insérez ici votre traduction
