Aller au contenu principal
Anglais
Français
Traduction de l’étape 2
Étape 2
Always wear gloves and eye protection when working with automotive fluids. If your car has been running recently, the engine and exhaust components may be very hot. Locate the oil drain plug along the side of the oil pan. It is a 14 mm hex bolt that faces towards the driver side of the car.
Draining the old oil
  • Always wear gloves and eye protection when working with automotive fluids. If your car has been running recently, the engine and exhaust components may be very hot.
  • Locate the oil drain plug along the side of the oil pan. It is a 14 mm hex bolt that faces towards the driver side of the car.
  • Place an oil drain pan under the oil drain plug to catch the old oil.
  • Use a 14 mm box end wrench to loosen the drain plug until you can turn it by hand.
Insérez ici votre traduction
