Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 4
Étape 4
The drain plug is a 17 mm hex bolt located on the underside of the tractor. Place an oil drain pan underneath the drain plug to catch the oil when it begins to drain. Use a 17 mm box end wrench to loosen the drain plug 3/4 of a turn.
Draining the old oil
  • The drain plug is a 17 mm hex bolt located on the underside of the tractor.
  • Place an oil drain pan underneath the drain plug to catch the oil when it begins to drain.
  • Use a 17 mm box end wrench to loosen the drain plug 3/4 of a turn.
Insérez ici votre traduction
