Aller au contenu principal
Anglais
Français
Traduction de l’étape 7
Étape 7
Wipe down the area around the drain plug with a clean rag or towel. Reinstall the drain plug and tighten it as much as you can by hand. Use a 17 mm box end wrench to tighten the drain plug until it is snug.
  • Wipe down the area around the drain plug with a clean rag or towel.
  • Reinstall the drain plug and tighten it as much as you can by hand.
  • Use a 17 mm box end wrench to tighten the drain plug until it is snug.
  • Do not over-tighten the drain plug. Doing so may strip the threads or crack the oil pan. You can always come back later and tighten the drain plug more if needed.
Insérez ici votre traduction
