Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Anglais
Français
Traduction de l’étape 13
Étape 13
Locate the oil dipstick. It is just below the front passenger corner of the engine. The dipstick has a bright yellow handle. Pull out the oil dipstick, wipe it off, place it all the way back into its hole and remove it again. Check the oil level on the end of the dipstick. It should be between the two holes or slightly above the top one.
  • Locate the oil dipstick. It is just below the front passenger corner of the engine. The dipstick has a bright yellow handle.
  • Pull out the oil dipstick, wipe it off, place it all the way back into its hole and remove it again.
  • Check the oil level on the end of the dipstick. It should be between the two holes or slightly above the top one.
  • This is not your actual oil level, but a pre-check to make sure the engine will not run dry when you first start it. The oil level will drop slightly after the first run when oil fills the new oil filter.
  • Add oil if the oil level is below the bottom hole of the dipstick. Place the oil dipstick all the way back in its hole.
Insérez ici votre traduction
