Anglais
Français
Traduction de l’étape 9
Étape 9
Tilt the motorcycle up off of its kickstand until it is vertical so that you can check the oil level through the sighting glass. The oil level should read somewhere between the "Low" and "Full" marks.
  • Tilt the motorcycle up off of its kickstand until it is vertical so that you can check the oil level through the sighting glass.
  • The oil level should read somewhere between the "Low" and "Full" marks.
    • It is common for the level to read a little high immediately after an oil change because the oil has not yet seeped into the nooks and crannies of the engine.
  • After starting the motorcycle and rechecking the oil level, you may add or remove oil as you see fit, then place the oil filler cap back over the oil filler hole. Turn the cap clockwise until it is snug.
Insérez ici votre traduction
