Aller au contenu principal
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
To open the Linksys WAP11, you will need a Phillips #1 screwdriver and a pair of metal tweezers. Use the tweezers to remove the two rubber boots on the front two legs. The easiest way to do this is to insert the tweezers into the hole in the face of the boot.  Once you are hooked behind the boot, pull outwards. This will reveal two small Phillips-head screws.  Remove them.
  • To open the Linksys WAP11, you will need a Phillips #1 screwdriver and a pair of metal tweezers.
  • Use the tweezers to remove the two rubber boots on the front two legs. The easiest way to do this is to insert the tweezers into the hole in the face of the boot. Once you are hooked behind the boot, pull outwards.
  • This will reveal two small Phillips-head screws. Remove them.
  • Keep these two screws together.
Insérez ici votre traduction
