Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel% qui comprend cette étape.
Traduction de l’étape 1
Étape 1
At this point, you may want to remove the antenna leads as well. Once the antennas have been removed, proceed to remove the remaining three phillips screws fastening the motherboard to the case.
  • At this point, you may want to remove the antenna leads as well.
  • Once the antennas have been removed, proceed to remove the remaining three phillips screws fastening the motherboard to the case.
  • Once the screws are removed, your motherboard will separate from the housing.
  • Keep these three screws together and separate from the outer case screws.
Insérez ici votre traduction
