Aller au contenu principal
Anglais
Français
Traduction de l’étape 1
Étape 1
Unlike the X360 Power Brick, these rubber boots require no tools to pry them up. Simply get your fingernails underneath and gently pull them up. Several people have commented that these boots were much more challenging to remove than mine were. Remove the 4 screws with your T10 security bit driver.
Remove Rubber Boots
  • Unlike the X360 Power Brick, these rubber boots require no tools to pry them up. Simply get your fingernails underneath and gently pull them up.
  • Several people have commented that these boots were much more challenging to remove than mine were.
  • Remove the 4 screws with your T10 security bit driver.
À l’inverse du bloc d’alimentation de la Xbox 360, ces pieds en caoutchouc ne requièrent aucun outil pour les enlever. Passez simplement votre ongle dessous et retirez-les avec soin.
Plusieurs personnes ont commenté en disant que ces pieds étaient bien plus compliqués à retirer que les miens.
Dévissez les 4 vis avec un tournevis Torx inviolable T10.
