Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 1
Étape 1
Before you begin, switch the ignition off and remove the key. Make sure the transmission is in Park (or first gear if you have a manual gearbox) and that the parking brake is engaged. Put on work gloves and safety goggles if you have them available.
  • Before you begin, switch the ignition off and remove the key.
  • Make sure the transmission is in Park (or first gear if you have a manual gearbox) and that the parking brake is engaged.
  • Put on work gloves and safety goggles if you have them available.
  • In addition to being dirty, the battery contains corrosive agents and may release flammable gases.
  • Gloves can also help protect you from an unpleasant shock if you accidentally mishandle the battery.
Insérez ici votre traduction
