Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 5
Étape 5
Locate the battery. It's normally rectangular and roughly 8-14" across. The battery may be easy to spot, or it may lie under a plastic cover—usually marked with positive (+) and/or negative (-) symbols. On some models, the battery may be located in the trunk—usually under or behind the trunk lining. Look around or consult your owner's manual.
  • Locate the battery. It's normally rectangular and roughly 8-14" across.
  • The battery may be easy to spot, or it may lie under a plastic cover—usually marked with positive (+) and/or negative (-) symbols.
  • On some models, the battery may be located in the trunk—usually under or behind the trunk lining. Look around or consult your owner's manual.
Insérez ici votre traduction
