Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 6
Étape 6
Using a correctly sized wrench or socket, loosen the nut/bolt securing the cable on the negative battery terminal. Always disconnect the negative cable first (before removing the positive cable). The negative terminal may be marked with a minus (-) symbol, or it may be unmarked. The positive terminal is almost always marked with a plus (+) symbol, often in red.
  • Using a correctly sized wrench or socket, loosen the nut/bolt securing the cable on the negative battery terminal.
  • Always disconnect the negative cable first (before removing the positive cable).
  • The negative terminal may be marked with a minus (-) symbol, or it may be unmarked. The positive terminal is almost always marked with a plus (+) symbol, often in red.
  • If the nut or bolt spins without loosening, it may be necessary to counter-hold the opposite side with a second wrench or socket.
Insérez ici votre traduction
