Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 4
Étape 4
Locate a secure jack point in the part of the vehicle that you want to raise.
  • Locate a secure jack point in the part of the vehicle that you want to raise.
  • A secure jack point is either:
  • An area designed specifically to make contact with the jack, or
  • An area that you know can safely support the full weight of the vehicle, without slipping off the jack.
  • Check your owner's manual for the locations of your vehicle's jack points. There is typically one near each wheel. There may be an additional jack point between the front wheels, and another between the rear wheels. If you're not sure, get some help.
  • Do not put the jack under a body panel, as shown in this photo. Apart from the obvious damage to the vehicle, this incorrect procedure can injure or kill you. The jack should make contact with a sturdy, unpainted area of the vehicle's frame.
Insérez ici votre traduction
