Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 6
Étape 6
remove 2 screws holding motor to battery compartment that were hidden beneath jack and wiring near battery opening. Lift motor housing up slightly to allow battery compartment to be removed. You may have to "wiggle" neck joint/silver attachment to allow this. The removed battery compartment. You will need to use a sharp blade to cut along joins to fully access battery contacts for a thorough clean.
  • remove 2 screws holding motor to battery compartment that were hidden beneath jack and wiring near battery opening.
  • Lift motor housing up slightly to allow battery compartment to be removed. You may have to "wiggle" neck joint/silver attachment to allow this.
  • The removed battery compartment. You will need to use a sharp blade to cut along joins to fully access battery contacts for a thorough clean.
Insérez ici votre traduction
