Aller au contenu principal
Anglais
Français
Traduction de l’étape 1
Étape 1
Opening the Retina iMac's can be tricky and you need the right tools. And you're going to need a few things to open the case and to install the SSD correctly.
  • Opening the Retina iMac's can be tricky and you need the right tools. And you're going to need a few things to open the case and to install the SSD correctly.
  • Here's the current iFixit tear down that shows you what you're getting into. iMac Intel 27" Retina 5K Display Teardown
  • And from our friends at OWC, they have a great video on taking the HDD complete out and replacing it with an SSD, but this guide will show how to simply leave the HDD and install the SSD. https://vimeo.com/139364064
  • Make sure to grab the essential tools like: Pro Tech Toolkit and Jimmy for opening up the iMac, although I used a medical scalpel, I found that the "guitar pick" was too weak and too thick. The "Jimmy" would be a great substitute for a scalpel.
  • You will also need the OWC In-Line digital thermal sensor, so that the iMac temperature control stays under control. Otherwise you fans will spin at full speed. This OWC kit also includes the needed tape to close you iMac back up. https://eshop.macsales.com/item/Other%20...
Ouvrir un iMac Retina peut être compliqué, et vous avez besoin des bons outils. Vous aurez aussi besoin de quelques petites choses pour ouvrir le boîtier et installer le SSD correctement.
Voici le tutoriel de démontage iFixit qui vous montre comment l'ouvrir. Démontage de l'iMac 27" Retina 5K.
Nos amis de OWC ont une excellente vidéo montrant comment enlever complètement le disque dur et le remplacer par un SSD, mais ce tutoriel vous montrera comment simplement laisser le disque dur et installer le SSD. https://vimeo.com/139364064
Assurez-vous de récupérer les outils indispensables tels que le Pro Tech Toolkit et le Jimmy pour ouvrir l'iMac. Personnellement, j'ai utilisé un scalpel médical, j'ai trouvé que le "médiator" était trop mou et trop épais. Le "Jimmy" sera un très bon substitut au scalpel.
Vous aurez aussi besoin du capteur de température OWC In-Line Digital, afin que la température de l'iMac reste sous contrôle. Sinon, vos ventilateurs vont tourner à pleine vitesse. Le kit OWC inclut également la bande adhésive nécessaire pour refermer votre iMac. https://eshop.macsales.com/item/OWC/DIDI...
