Aller au contenu principal
Anglais
Français
Traduction de l’étape 5
Étape 5
For the final step I simply zip tied the thermal sensor cable to the HDD bracket to keep everything in place. I also wanted to pull the OWC cable down away from the display as much as possible. As you can see from the second picture there is still plenty of room as the OWC cable and zip tie are well below the HDD and fan exhaust.
  • For the final step I simply zip tied the thermal sensor cable to the HDD bracket to keep everything in place.
  • I also wanted to pull the OWC cable down away from the display as much as possible. As you can see from the second picture there is still plenty of room as the OWC cable and zip tie are well below the HDD and fan exhaust.
Pour l'étape finale, j'ai simplement attaché le câble du capteur de température au support du disque dur avec un collier, afin de le maintenir en place.
Je voulais également éloigner le câble OWC autant que possible de l'écran. Comme vous pouvez le voir sur la seconde image, il y a toujours beaucoup de place, car le câble OWC et le collier sont bien en-dessous du disque dur et de la sortie du ventilateur.
