Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 7
Étape 7
In place of the headphone jack, we find a component that seems to channel sound from outside the phone into the microphone... or from the Taptic Engine out. No fancy electronics here, just some well-designed acoustics and molded plastic. Teardown Update: According to Apple, this plastic component is a barometric vent. With the added ingress protection afforded by the watertight seal, the iPhone uses this baffle to equalize the internal and atmospheric pressures in order to have an accurate altimeter.
  • In place of the headphone jack, we find a component that seems to channel sound from outside the phone into the microphone... or from the Taptic Engine out.
  • No fancy electronics here, just some well-designed acoustics and molded plastic.
  • Teardown Update: According to Apple, this plastic component is a barometric vent. With the added ingress protection afforded by the watertight seal, the iPhone uses this baffle to equalize the internal and atmospheric pressures in order to have an accurate altimeter.
  • Mechanical buttons are a thing of the past when you have a Taptic Engine! This sleek engine uses haptic feedback to simulate the push of a button, without having a real button.
  • Anyone familiar with the touchpad in the Retina MacBook 2015 has already experienced haptics from the Taptic Engine.
À la place de la prise jack, nous découvrons un composant qui semble faire passer le son de l'extérieur du téléphone au microphone... ou du Taptic Engine.
Pas d'électronique sophistiquée ici, juste quelques pièces acoustiques bien conçues et du plastique moulé.
Mise à jour démontage : selon Apple, ce composant en plastique est un conduit pour le baromètre. Suite à la meilleure protection contre les dégâts des eaux apportée par le joint étanche, l'iPhone se sert de ce régulateur pour égaliser la pression atmosphérique à l'intérieur et à l'extérieur et avoir un altimètre précis.
Les boutons mécaniques appartiennent au passé quand vous avez un Taptic Engine ! Cet engin élégant utilise un dispositif haptique pour simuler la pression sur un bouton, sans en avoir un vrai.
Tous ceux qui ont déjà touché le touchpad du MacBook Rétina 2015 connaissent le ressenti tactile du Taptic Engine.
