Aller au contenu principal
Anglais
Français
Traduction de l’étape 14
Étape 14
Repeat the above procedure to separate the second, lower battery cell from the rear case. Insert your cards only from the top edge of the battery cell and from the side opposite the logic board. Don't use any cards to pry under the battery from the bottom edge of the iPad, or you may damage ribbon cables for the speakers, antennas, and Lightning connector. Insert your cards only from the top edge of the battery cell and from the side opposite the logic board. Don't use any cards to pry under the battery from the bottom edge of the iPad, or you may damage ribbon cables for the speakers, antennas, and Lightning connector.
  • Repeat the above procedure to separate the second, lower battery cell from the rear case.
  • Insert your cards only from the top edge of the battery cell and from the side opposite the logic board. Don't use any cards to pry under the battery from the bottom edge of the iPad, or you may damage ribbon cables for the speakers, antennas, and Lightning connector.
Répétez la procédure ci-dessus pour séparer la seconde cellule de batterie, l'inférieure, de la coque arrière.
Insérez vos cartes uniquement depuis le bord supérieur de la cellule et du côté opposé à la carte mère. N'utilisez pas de cartes pour pénétrer sous la batterie depuis le bord inférieur de l'iPad, vous risqueriez d'endommager les nappes des haut-parleurs, des antennes et du connecteur de charge Lightning.
