Aller au contenu principal
Anglais
Français
Traduction de l’étape 16
Étape 16
Use an opening pick to slice through the adhesive directly underneath the battery connector terminal. There's a small standoff in the case that helps seat this connector. The pick may be obstructed by this. Simply work the pick around each side of the standoff to slice through the adhesive.
  • Use an opening pick to slice through the adhesive directly underneath the battery connector terminal.
  • There's a small standoff in the case that helps seat this connector. The pick may be obstructed by this. Simply work the pick around each side of the standoff to slice through the adhesive.
Utilisez un médiator pour découper l'adhésif directement sous la borne du connecteur de la batterie.
Dans la coque se trouve un petit dispositif de retenue qui maintient ce connecteur et peut bloquer le médiator. Il suffit de découper l'adhésif de chaque côté du dispositif.
