Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 7
Étape 7
The third, and final, cable you will need to unplug is the TMDS connector. This is located under a rectangular strip of black tape that has a gray and black cord coming out of one end. Peel back the black tape, starting at the end with the cords protruding out.
  • The third, and final, cable you will need to unplug is the TMDS connector. This is located under a rectangular strip of black tape that has a gray and black cord coming out of one end.
  • Peel back the black tape, starting at the end with the cords protruding out.
  • Under the black tape, you will see the gray and black cords going into a connection that looks like it is wrapped in aluminum foil. Grasp that connection and pull carefully in the downward direction toward the bottom of the display.
Insérez ici votre traduction
