Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 3
Étape 3
Use the plastic opening tool to carefully lift the motherboard off one corner at a time. Lift the motherboard slowly away from the keyboard because there is a cable attached to bottom of the motherboard.
  • Use the plastic opening tool to carefully lift the motherboard off one corner at a time.
  • Lift the motherboard slowly away from the keyboard because there is a cable attached to bottom of the motherboard.
  • If the motherboard is not easily removed by pulling, then lift one side of the motherboard until you can see the attached cable. Then use the plastic opening tool to detach the cable from the motherboard.
Insérez ici votre traduction
