Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront les tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
With the monitor facing down, remove the two 5.81 mm Phillips #2 screws on the right side of the metal casing. With the monitor still facing down, remove the two 5.81 mm Phillips #2 screws on the left side of the casing. Do attempt to pull apart the casing.  There are still wires holding the front and back together.
  • With the monitor facing down, remove the two 5.81 mm Phillips #2 screws on the right side of the metal casing.
  • With the monitor still facing down, remove the two 5.81 mm Phillips #2 screws on the left side of the casing.
  • Do attempt to pull apart the casing. There are still wires holding the front and back together.
Insérez ici votre traduction
