Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront les tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
The inverter board is the smaller board in the corner. Remove the three 7.69 mm Phillips #2 screws from the inverter board.
  • The inverter board is the smaller board in the corner.
  • Remove the three 7.69 mm Phillips #2 screws from the inverter board.
  • Remove the two 7.69 mm Phillips #2 grounding screws from the wire with the black connector.
  • Gently pull the inverter board away from the case. Note that the board is still connected to several components by wires.
Insérez ici votre traduction
