Aller au contenu principal
Anglais
Français
Traduction de l’étape 1
Étape 1
The EM10 charging filter is located next to the power connector on the motherboard.
  • The EM10 charging filter is located next to the power connector on the motherboard.
  • If the filter is missing or obviously broken, move on to STEP 18
  • Use a multimeter to test the EM10 filter - measure the resistance between each of the yellow solder pads, and then between each of the cyan solder pads. If everything is OK you should have close to 0 Ohms between each set of pads. You should NOT have any connection between the cyan pads and yellow pads. If the filter fails either test it needs to be replaced.
Insérez ici votre traduction
