Aller au contenu principal
Anglais
Français
Traduction de l’étape 6
Étape 6
Carefully insert the cable from your new trackpad through its slot cut into the upper case. Use one hand to hold the trackpad cable in place as you insert the two retaining tabs on the outer edge of the trackpad under the lip on the upper case.
  • Carefully insert the cable from your new trackpad through its slot cut into the upper case.
  • Use one hand to hold the trackpad cable in place as you insert the two retaining tabs on the outer edge of the trackpad under the lip on the upper case.
  • Pull the trackpad cable as you seat the trackpad into its void in the upper case.
Insérez ici votre traduction
