Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront les tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Use a plastic opening tool to gently pry the bottom cover loose. Do not use excessive force at risk of damaging the antenna, which is under this casing. Pull the cover from the front of the phone after the back is loose.
  • Use a plastic opening tool to gently pry the bottom cover loose.
  • Do not use excessive force at risk of damaging the antenna, which is under this casing.
  • Pull the cover from the front of the phone after the back is loose.
Insérez ici votre traduction
