Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 8
Étape 8
Rotate the printer 180 degrees and turn it up on to the front side, so that the back of the printer is facing up and the bottom facing you. Be careful because the feed roller assembly is now loose, but it is still attached to the main body of the printer. Push in the tab on the left side of the back panel and pull outward to remove the back panel.
  • Rotate the printer 180 degrees and turn it up on to the front side, so that the back of the printer is facing up and the bottom facing you.
  • Be careful because the feed roller assembly is now loose, but it is still attached to the main body of the printer.
  • Push in the tab on the left side of the back panel and pull outward to remove the back panel.
Insérez ici votre traduction
