Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 2
Étape 2
Insert the spudger into the crack between the green rubber container and the plastic case and pry it out.  When the cell it is about halfway out, remove the spudger. Reinsert the spudger into the crack between the metal top and the plastic case and pry it the rest of the way out. Reinsert the spudger into the crack between the metal top and the plastic case and pry it the rest of the way out.
  • Insert the spudger into the crack between the green rubber container and the plastic case and pry it out. When the cell it is about halfway out, remove the spudger.
  • Reinsert the spudger into the crack between the metal top and the plastic case and pry it the rest of the way out.
Insérez le spudger dans la fissure entre le récipient en caoutchouc vert et le boîtier en plastique et évacuez-le. Lorsque la cellule est à peu près à mi-distance, retirez le spudger.
Réinsérez le spudger dans la fissure entre le dessus en métal et le boîtier en plastique et tirez le reste du chemin.
