Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel% qui comprend cette étape.
Traduction de l’étape 1
Étape 1
After opening the chassis, you will see a white bulb spanning the width of the scanner. Lift up the black piece of plastic the bulb is attached to from the left hand side until it is perpendicular with the bottom lid of the scanner.
Locate the bulb
  • After opening the chassis, you will see a white bulb spanning the width of the scanner.
  • Lift up the black piece of plastic the bulb is attached to from the left hand side until it is perpendicular with the bottom lid of the scanner.
Insérez ici votre traduction
