Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 1
Étape 1
Lift up the central plastic housing inside the scanner. There are four plastic tabs located on the outer plastic housing. Push on each of these and pull to remove it. Underneath you will see that the ribbon cable is attached to the circuit board.
Remove outer plastic housing
  • Lift up the central plastic housing inside the scanner.
  • There are four plastic tabs located on the outer plastic housing. Push on each of these and pull to remove it.
  • Underneath you will see that the ribbon cable is attached to the circuit board.
Insérez ici votre traduction
