Aller au contenu principal
Anglais
Français
Traduction de l’étape 1
Étape 1
Facing the front of the scanner you will see a white plastic wheel holding the other end of the tread. Pull the spring towards you until it snaps off the side wall releasing the tension in the spring.
  • Facing the front of the scanner you will see a white plastic wheel holding the other end of the tread.
  • Pull the spring towards you until it snaps off the side wall releasing the tension in the spring.
  • Using a #2 Philips Screwdriver, unscrew the single 5.88mm screw holding the mount of the plastic wheel in place.
Insérez ici votre traduction
