Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 20 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
During reassembly, be sure to carefully position the pressure contact back in place. It should rest on top of the Philips screw post shown, and the gold contact should point towards the battery connector. Be sure to clean the pressure contact with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
Reassembly tip
  • During reassembly, be sure to carefully position the pressure contact back in place. It should rest on top of the Philips screw post shown, and the gold contact should point towards the battery connector.
  • Be sure to clean the pressure contact with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
Avant de replacer le connecteur de la batterie lors du remontage, positionnez soigneusement le contact à pression à sa place. Il doit reposer sur le dessus de la vis cruciforme montrée ci-contre et le contact en or doit pointer vers le connecteur de batterie.
Assurez-vous de nettoyer le contact à pression avec un dégraissant comme du Windex ou de l'alcool isopropylique. Le sébum sur vos doigts peut en effet provoquer de graves interférences.
-[* icon_reminder] Before you reattach the battery connector during reassembly, carefully position the pressure contact back in place. It should rest on top of the Philips screw post shown, and the gold contact should point towards the battery connector.
+[title] Reassembly tip
+[* icon_reminder] During reassembly, be sure to carefully position the pressure contact back in place. It should rest on top of the Philips screw post shown, and the gold contact should point towards the battery connector.
[* icon_note] Be sure to clean the pressure contact with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
