Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Remove the rubber inserts inside the the two purple feet located on the router's front case.
  • Remove the rubber inserts inside the the two purple feet located on the router's front case.
  • This may be a challenge, so try the following two methods:
  • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
  • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
Insérez ici votre traduction
