Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
Carefully unplug the 3 wire connections by placing a plastic spudger under the connections and lifting up. Disconnect the battery and speaker connections by placing the round handle spudger under the wires and lifting up and out. Disconnect the display connections from the motherboard by using the plastic spudger to lift the clamp holding the ribbon cable. Then, using the tweezers, grab the ribbon wire and pull away from the motherboard.
  • Carefully unplug the 3 wire connections by placing a plastic spudger under the connections and lifting up.
  • Disconnect the battery and speaker connections by placing the round handle spudger under the wires and lifting up and out.
  • Disconnect the display connections from the motherboard by using the plastic spudger to lift the clamp holding the ribbon cable. Then, using the tweezers, grab the ribbon wire and pull away from the motherboard.
Insérez ici votre traduction
